Old 09-27-2010, 10:55 AM   #46
ochowdero
not saying its directly involved in ignition but it aids in correct timing of the spark..IE combustion..
if you got the car running and it doesnt respond at high rpms as well as low, this will also result in a faulty distributor, as well as leaks..(mostlikely the leaks, bad distributors are not likely, but are sometimes a missed thought of correction)
