Originally Posted by Busted Knuckles
You should be getting 'infinite' ohms, meaning no resistance. Zero ohms means a break somewhere, and anything else means a corroded ground connection somewhere causing a resistance.
Close, you actually have it backwards though. 0 ohms means almost no resistance, meaning a good conductive wire. Infinite ohms (often represented with a "1" at the beginning of the display on a digital multimeter) means that the 2 reference points are not connected to each other electrically
