Old 10-04-2010, 12:05 AM   #25
Then look closer... I'm not making it up. The top half and bottom separate and each section of the inside of the upper comes out individually. The fusible links do not pull out from the top.
The contained module versus wire is just a matter of preference and are interchangeable... it's just as possible that yours was replaced once already with a wire FL.... it's also possible that some jackass replaced it with regular wire (BAD idea).
