Can I do this?????
I know there are threads about 1jz swaps but I cant find the answer I was looking for. I recently wanted to do a 1jz swap but was so confused over the wiring. I found a supra with a 1jz swap, the same exact year as mine. However the body and interior is kinda bad, and it is auto. I was wondering can I do the swap and use the wiring but keep my trans. If I cant what should I do. Thanks for your guys help in the past and I relay appropriate all the help you guys give.
