Originally Posted by jcastro
I know there are threads about 1jz swaps but I cant find the answer I was looking for. I recently wanted to do a 1jz swap but was so confused over the wiring. I found a supra with a 1jz swap, the same exact year as mine. However the body and interior is kinda bad, and it is auto. I was wondering can I do the swap and use the wiring but keep my trans. If I cant what should I do. Thanks for your guys help in the past and I relay appropriate all the help you guys give.
Yeah u can. U will have to bypass the nutruel switch. and get a r154 transmission belhousing. About 400 bucks. Plus u would need a flywheel which is about 300 bucks. Plus a new clutch 250 which I'd recomend for any swap.. I didnt and mine is now slipping. Never use a used clutch.. so it really wouldn save u much money. If your worried about the harness just send it to Dr tweek.
And be aware that harness still may not plug into your car depending if they made plug adapters or hard wired the jza70 plugs on the chassis... pm me your email address and ill send u pics of my harness and what I did to it.. I did it in a way I didn't cut my chassis plugs or harness plugs. just had to extend it. It really isn't that hard at all just time consuming. It took me a 3 day weekend to do just the harness.
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
