Originally Posted by jcastro
Ya true but I can get this car for 3gs and take out the 1jz put my 7mgte and get it running and sell it. Then i plan to just plug and play with my car and the 1jz.
In a perfect world that would work. But I have 50 bucks on it that he cut the chassis harness and put the jz plugs on it. So the 7m won't plug back up to those plugs. nor will the jz plug into your car. But it depends how the harness was modded and the quality of the job done. It would be hell to trouble shoot an extended harness as there is over 250 locations it could go wrong. Even just a break in the wire would suck to find. With out cutting and soldering either the harness or your chassis it pribably wont plug in.. UNLESS he put the 7mgte plugs on the jz harness then it would be pretty smooth. If the harness was done properly.. basically the same thing u have to do any route u go. I paid 3g for the front clip and it was a manual.. cuz your looking about 1g for parts to convert the jz to manual..
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
