Originally Posted by supraman623
im not sure what the differences actually are but i know the 93 and 94 supra tt had a little bit beafier rear differential. the 93-96 6 speed used a v160 tranny and the 97 and 98 used a v161. not much differences between the two trannys. just the length of the gears. hope this helps
Actually there's no difference in the diffs for the 6spd. '96+ Mkiv
autos didn't have a torsen diff however (so one-wheel-peel is a problem).
The '96+ Abs system is not as feature-rich, but the engine bay is a bit cleaner. Of course '96+'s are OBDII vs OBDI. Other than that, they're all the same.
