Here just put this in another post so its handy. The rusty pipe is were the 90 degree hose hooks to, you can see the hose under the pipe disconnected and sitting there. If I were you I would do what I did lol, replace the lower hose and the 90 degree at the same time since you have to take the same stuff apart to get to both. The 90 degree hose can be sourced from autozone or napa or anywhere just go in with the hose and tell them you want to see if they have anything that will match it in there hose section. Usually they just let me go back to the wall of hoses and match it myself because they dont want to. But should be able to match one for $15 at most, may have to cut it down from a longer one but not hard. I think I paid $7 for the one I got. Sorry didn't write down the part number. At some point you should just save up the money and replace every hose on the car, that is the best way to make it the most reliable and will only cost $100 or so for all of them. here is the pic
