It's your piston rings. They don't always show low on all cylinders. 90psi. is definatly not caused from a bad heasgasket. But since it is free to test it. its worth a try. but I got 100 bucks on rings... rings wear out on any car regardless of make. Although they are not as prone to ring problems as they are bhg. They do wear out. In your situation is say rings.. especially unit has high mileage. Or has the boost cranked up above stock
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
