Old 10-11-2010, 10:03 PM   #5
supralou42
supralou42 is on a distinguished road
Default won't start
If it does not want to turn over (crank) check the ignition start switch.
run a wire from the starter solonoid thin wire, blue in color. turn on the ignition switch. touch the wire from the starter to the pos terminal of the batt. if engine cranks and starts, you have a bad ign switch.
supralou42 is offline   Reply With Quote
