found it. I hope this helps someone who has same problem.
it goes down to a vacuum valve on the top of the power steering pump. There are two lines connected to the power steering vsv, one goes to bottom side of accordion and the other goes to the metal bypass line that goes around front of motor and connects to the main vacuum distribution line under the front area of the plenum.
