Yeah,
That can be a really smart upgrade to have when altering stock boost levels. To accompany it you will want an afr gauge though, this will tell you when you're running lean or rich... or hopefully Stoich! therefore telling you in which direction you need to adjust your afr regulator.
Again you'll also want the upgrades listed above. Those will allow 11-15 psi.
