Old 10-14-2010, 10:43 PM   #2
Cameroonski
Cameroonski is on a distinguished road
You can get a complete coilover set for less then a grand. Google showed some for about $700. Or if you just replace the strut, because springs dont really go bad as easily, your looking at about 450 for tokico illumina 2's... which are pretty nice, its what i have. add some eibach lowering springs to those, is another 250 dollars. If you replace the entire coilover (strut and spring) you can install it yourself... if you are replacing one componet (strut OR spring) you need a special tool to compress one while seperating the other. So I would recommend a complete coil over kit, and replace them yourself.
Cameroonski is offline   Reply With Quote
