5m cranks but will not start
so i had a cracked head, i replaced it with an older 5mge head and obviously did my HG. i replaced out the old distributor with the one from the head i removed(dist. had some sort of vacuum advance.) also replaced the thermostat housing thing, with the one off my old head.
also put in injectors and fuel rail i just had sitting around.
the engine cranks, but isnt starting.... any thoughts??
im gona check to make sure im getting spark later on this weekend...
i set the #1 cylinder to TDC and both cam gears to proper marks. dist. may be a bit off but it should still start.
and before i did the job, i was getting spark....
i really hope there was just some bad gas in the injectors and rain i put on and its gona take some cranking to get it out
any thoughts would be good
