Originally Posted by 89ST
If your break pedal has to be pushed to the floor to receive any substantial braking force than you have air in your brake lines. Maybe you should bleed them again, and make sure you're doing it properly.
What are the symptoms of your turbo not working? not boosting at all? lower boost than usual? Then maybe i can help.
i do not know. it seem that i am over boosting... i have a greddy profec the inlet is in the wastegate and the out ish tpo the turbo
