Old 10-19-2010, 06:33 AM   #10
zby67
zby67's Avatar
zby67 is on a distinguished road
Originally Posted by Grandavi View Post
I dont think it has anything to do with the compression really..
The engine is only capable of doing so much by itself.. if you understand how a turbo works (I will use the way I 'splained it to my kids) the turbo is like taking your girlfriend and giving her a straw... then putting a milkshake in front of her. Time how long it takes her to suck up one strawful of milkshake (no.. not sexual thoughts here..)
Then.. fill the straw with milkshake and blow it into her mouth as hard as you can. Thats.. boost.
A NA engine is sucking air.. while a turbo has the benefit of a pump pushing the air. Makes one helluva difference. You aren't going to defy physics by wishing it was different.
Remember.. I am not a mechanic.. but a NA (naturally aspirated engine) is forced to suck its air/fuel mixture. A turbo is beautiful because the exhaust will spin a tubine which pushes it in. Superchargers use the crank (unless they changed it) so they actually cost HP to run.. (if I remember correctly a 350 HP supercharger can use 50HP just to push the air)
Its probably far more complex.. but the engine does have its limitations.. and 300 HP is far past that if I understand its engineering. It just simply cant be done "normally" without possibly pumping 1000's and 1000's of dollars into it. So... its better that you take the NA and sell it for whatever you can get for it and put a 7MGTE into it (or a 1JZ) Your farther ahead and will save yourself a massive amount of headache..
of course.. this is an opinion from a guy sitting behind a computer.. not over top of an engine bay.
i understand how a turbo works. i just dont see why you wont see more hp with boring over and a 3" exhaust it still lets out more air. but i see your point just cause your sucking in a shit tone of air dosnt mean anything unless you can get ride of i quickly. so just do a stock rebuild new exhaust and cold air intake then start saving up for a GTE swap? and how much would boring over the GE actually help or will it hinder>? then once i get the GTE take everything i added to the GE and put it on the GTE cause im getting most of this from suprastore and there kits ment mostly for the GTE's anyway
1986.5 MA70 7M-GE
1987 MA70 7M-GE
zby67 is offline   Reply With Quote
