Originally Posted by btwilson86
Oh, okay. Those are the intake plenum's and the throttle body's.
The GE intake utilizes the Toyota ACIS system (info found here), whereas the GTE intake does not. Without this system, you will likely notice a decrease in power.
For example, 7M Cressidas are rated at about 15hp less than GE Supra's. Cressidas use an intake design more similar to the GTE than the GE.
so then vary vary bad idea to put that plenum of GTE on the GE ok thank you for the info! im trying to get the GE up as high as i can with out going turbo. im not one for turbo's.
