Old 10-25-2010, 04:07 AM   #1
lawliu89
lawliu89 is on a distinguished road
Question Mk3 overheating please help
HELP, I have a 87 supra turbo and it overheats really quickly. Im new to the car and i have looked through the forums and figured it probable is a BHG but im still not sure of the problem cause it matches some of the symptoms but i just wanna clarify. I cant get it checked by a mechanic because the car cant even make it out of my neighboorrhood without the temperature guage hitting max loool. When the car starts to overheat, the radiator cap starts fuming water vapor or something? and theres a little bit of coolant residue as well.
BHG symptoms is large amount of white smoke from the exhaust and fumming from where you put the coolant, but theres little white smoke, and its probably cause it was cold (canada lool) and the coolant wasnt boiling from the bottle u put coolant in the car.
The engine oil cap has a little bit of white crust on the lid if that helps and it looks kinda milky? so hopefully the description helps and ill put a picture of the engine and the yellow circles where the smoking from the radiator cap is and i have pictures of the engine oil too.
PLEASE SHARE YOUR SUPRA WISDOM AND KNOWLEDGE WITH ME
ID:	3549   Click image for larger version
ID:	3550   Click image for larger version
ID:	3551   Click image for larger version
ID:	3552   Click image for larger version
lawliu89 is offline   Reply With Quote
