Thread: mk4 performance
Old 10-25-2010, 04:49 PM   #10
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by kylej View Post
6 speed manual trans, I don't think I would want a single turbo would it be possible to stay twin and reach 500whp?...
Yes, it'd be possible, but it's not practical. You'd spend about twice as much (or more) as you would simply going single turbo to get that 500rwhp.
...I just driving the car as a summer car and take it to the strip sometimes to race other people, it's like a Friday night thing at a local drag strip.
if I was to go with the 425-450 rwhp how much would it cost for the new turbo's, etc. that I would need to be brand new again?...
Last I recall, brand-new turbos from Toyota are about $2250 EACH, and a new shortblock is about $3,250 or so...
...i'm gonna go bpu++++, we will get whatever whp out of it we can without turbo upgrade, if i want i can do that and change everything later but as a daily driver 400whp approx, should do...
You'll need all the standard bpu stuff, plus an fmic, an aftermarket bov (recirc), adjustable cam gears, and a fuel controller. You'll need a spring on your wastegate, and you'll need to run about 25% race fuel to bump up the octane.
I've never bpu'd a Japanese-spec Mkiv myself. I believe you'll also need a speed limiter defensor. We may also need to find a way to get your downpipe connection made larger so you can run a full 3" US-spec downpipe.
Life begins at 30psi.
