Old 10-25-2010, 06:19 PM   #2
fantasma87
fantasma87's Avatar
i hope i`m right. i did it on my and you have to get under the dash on the driver side. looking straight to the steering rod you will see a small black box. theres a blue with orage stripe wire , cut it and one of the sides has to be grounded to the chasis ( not sure but I think is the side that is not going to the box). FIRST OF ALL , VERIFY IT WITH THE RADIO FUSE ON THE ENGINE BAY FIRST , TAKE IT OFF AND TRY TO CRANK IT , IF IT CRANKS THEN DO THE WIRE ON THE BOX. good luck and let us know before you cut the wire.
ARMY STRONG !!
