Thread: mk4 performance
Old 10-26-2010, 10:03 AM   #18
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by kylej View Post
Could you estime the price of bpu++++, 650whp set up and 800whp setup?
Do you care how it looks? Chroming, coatings, etc., etc. can add up to a lot. Are you going to be doing the labor yourself for the installs, or will you be paying someone?
Parts only: BPU+++ would be at least $3k. 650rwhp (6spd) would be about $12K-$15K (you'll need a fuel system and wider rims), and 800whp would be about $20K-$25K. The labor for these installs, dyno-tuning, etc. would be significant, since you should only use someone with extensive, verifiable 2jz-gte and extensive, verifiable 800+rwhp experience. Typically, a shop with that kind of expertise isn't cheap. Oh, and don't forget to maintain an ongoing budget for race fuel.
Again, have you read these two threads from the MKIV FAQ?
Life begins at 30psi.
