I was thinking he meant it took a long time of cranking to start not that it would not crank. The starter signal wire is not very good so if it wont crank you may want to look into the starter rewire. You use a ford starter relay to supply power to the starter. Otherwise if it cranks for extended periods but wont start check into the cold start switch.
