Originally Posted by kylej
Okay sweet dude thanks so much for your help, what size of rear rims will I need for 650rwhp, ill just get those off the start.
11.5" width on the rear rims is the main thing (with the correct offset and bolt pattern, of course). The diameter isn't that important ... any thing from 17" diameter through 20" diameter works fine - just be sure you can get the rubber to match. Don't forget - no low profile rubber on the rear - you need some flex to the rear sidewall to ensure traction. Check out tirerack.com ahead of time for available sizes. On the front, a 9.5" wide rim matches the 11.5" rear rim just fine. If you want to install a bigger front brake kit someday (roadracing application), you probably need at least an 18" diameter.
I'm glad to help! Welcome to the Mkiv Supra Turbo 'brotherhood'!
