Yeah I did check the timing with the jumper and it was at 10. It doesn't matter where I turn the CPS it still rins rough. I'll fix the air leak later today after work. One more note, it runs the same as before when I overheated the engine if that helps. It ran great before overheating though. The cause of overheating was due to a worn hose that blew out. Thanks all
