Thread: mk4 performance
Old 11-04-2010, 12:02 AM   #36
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by bioskyline View Post
The export version of the 2JZ-GTE achieved its higher power output with the use of newer stainless steel turbochargers (ceramic for Japanese models), revised camshafts, and larger injectors (550 cc/min for export, 440 cc/min for Japanese)
remember this, the jspec 2jz has a lower stock hp rating than the usdm 2jz. so your starting off with a lower power motor, so you need more upgrades to boost your power levels up. as the jspec 2jz uses ceramic turbos, ditch the twins for a large single and put bigger injectors in.
To me, a single probably isn't necessary, unless you know your short-term power goal exceeds 400rwhp. Swapping out the intake-side cam is pretty easy. Instead of swapping the injectors (and installing a resistor pack), just put in an adjustable fuel pressure regulator and run a higher base fuel pressure - this should allow the oem japanese-spec 440cc injectors to work just fine for bpu++++. That way you don't need an aftermarket fuel system till you go single.
Life begins at 30psi.
