Old 11-07-2010, 05:34 PM   #1
JDM Supgra
JDM Supgra is on a distinguished road
Default figured out the issue
I found where the engine light is located and noticed it does not turn on nor the oil light comes one when you open the ignition, I took that part of the circuit apart and noticed the solder on the connect pins were cracked, so resoldered them and was able to read the codes and I was getting code 42 which is vehicle speed sensor, so I guess I need to replace it.
Cheers,
Rafi
JDM Supgra is offline   Reply With Quote
