W58
I have A 89 supra with the w58 and the front seal is leaking so I took it to a transmission shop and they said that the rubber seharbor rock hard and cut a grove in the shaft so they said they will try to sand it down some to help it seal and new front and rear seals for 150$ or replace the shaft which is 850$ so I found a w58 out of a 87 supra but mine has a little box with a wire coming out of the top of the tranny and a wire coming out the side which is the backup lights switch right and the 87 w58 doesn't have the top wire. So what is it for.
