Old 11-17-2010, 11:53 PM   #2
There is a ground wire that runs to one of the four main bolts which mount the column. The ground is on the RH front bolt if I recall correctly. There are two bolts on each side and they're about 14mm with washers on them... look for the biggest screws by the column under the dash.
The problem being a poor connection at the same ground more than once is unlikely unless there is already a significant voltage drop elsewhere.
Use some punctuation, it makes it easier for people to help if they can easily read what you're trying to communicate.
