Old 11-19-2010, 09:41 PM   #17
Jackalope501
Jackalope501's Avatar
Jackalope501 is on a distinguished road
You're welcome...just trying to help guys. So much bullshit info out there makes it hard for people to get the right stuff...
Scroll back guys, I'm finishing out the post on buffing products above...
Let's start using your buffer....
Remember wetting and wringing out our applicator pad for waxing? Same process here. Wet and squeeze your applicator for applying your buffing product. It's also a good idea to shake up your products too...not just when you buff, but you want to agitate it a bit whenever you walk past it on the shelf. Keep it from settling or separating on ya...
Area coverage:
You can only work a 2ft x 2ft (approximate)area on the car at one time. to give you a better idea, let's use a Supra hood as an example. You have 3 distinct areas from one side to the other divided roughly in 3rds. Your 2 lower laying sides and the raised section in the center, right? Now take each one of those and cut it in half from the hood's front edge at the nosecap to the base of the windshield. That "1/6th" of the hood is all the area you can manage at once.
(Let me know if you need pics here to demonstrate)
Buffing products are designed to be applied wet, and worked while wet. Don't let them dry like you do wax.
Don't delay once you apply product to the hood. If your pad needs cleaned, spur it first...have the buffer ready to go once you put the product on...
Since we've already mentioned the hood, let's start there. This is one of the easier parts of a car to buff. I recommend starting on one of the outside "3rds" of it here for easier control. (Once you've practiced a bit, you'll typically start at the center section and work out to avoid touching the same area twice.) Be sure to drape your buffer's cord over your shoulder so you're not dragging it on fenders, etc. While I'm on that, never wear anything harder than sweats when you buff a car. No brass rivots on your jeans, no belt buckles, NOTHING that can scratch the car! Sweats are always your safest bet. Trust me, you're gonna be getting intimate with your car here and leaning all over it.
Jackalope501 is offline   Reply With Quote
