Old 11-20-2010, 10:10 PM   #18
Jackalope501
Jackalope501's Avatar
Jackalope501 is on a distinguished road
Default Buffing the Hood
You have your dampened applicator and buffing product in hand. Place about a quarter-sized dollop on the applicator, and wipe it on the 1/6th area we talked about earlier. Set your applicator aside (face up) and grab your buffer. (wool pad attached, 3000 rpm) Pull your trigger and set the buffer down flat on the surface you're buffing...moving side to side with the body lines of the hood, then back and forth to cross your patterns like a big "T". Keep your buffer moving at all times. Work this area until the surface comes out clean. Don't overdo it. You may leave a couple of small smut marks where you didn't get all the polish off...that's ok. Better to leave a couple of spots than attempting to grind them out.
Be particularly careful around windshield wipers, washer jets, trim, antennas, etc. the edges of your wool pad can snag one in a heartbeat and sling it across your shop. I'm not kidding. I've seen fuel doors, trim, rearview mirrors and hood ornaments ripped off of cars before. It happens in a nanosecond, so always be aware of your pad's proximity to hazards.
Practice that for a bit, and we'll pick up again later...
Jackalope501 is offline   Reply With Quote
