As usual, check for codes (even if the CEL is off).
I'm thinking either faulty Idle Speed Control valve, possibly vacuum leak. Check the TSRM for testing procedure of the ISC, and listen around the engine bay for vacuum leaks with the engine running. I believe an out of adjustment TPS may also cause this issue, testing and alignment procedures are also in the TSRM.
