Old 11-22-2010, 01:34 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Anthonyhuynh3 View Post
thank but to swap a GTE how much does it cost ?
Will you do the work yourself? Parts will probably cost $4000 or more. You need the engine, complete harness, ecu, ignitor, resistor pack, downpipe, and other items I'm not aware of. Labor for someone else to do the work will be about $1K I'd guess.
Be sure to get a leakdown & compression test on the engine before you buy it. Also be sure you have someone evaluate the leakdown & compression numbers who understands compression and leakdown tests, and is very familiar with both brand-new and used 2jz-gte engines.
Life begins at 30psi.
