I'm not sure how easily and cheaply you can find a 1jz ecu, it's generally easier to spend the extra and get a clip from Japan, that way you have most of the stuff that you need. As far as the tranny is concerned, the 7M turbo tranny is the same as the 1JZ tranny, except you will need the 1JZ Bellhousing to mate it to the engine.
