Old 11-22-2010, 06:46 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by ausupra View Post
Hey,
I'm about to pull the old girl to bits to do some fabrication, then I'll put her back together. I've been advised that the optimal torque for the crank is 15 ft/lb over standard but can't find standard torque specs for the life of me.
What is your crank torqued at? I have the ARP head/main studs.
Thanks
Do you have a TSRM? All the torque specs are in there. You shouldn't be pulling "the old girl to bits" and putting "her back together" without the TSRM.
Life begins at 30psi.
