Old 11-24-2010, 08:14 PM   #10
gringoloco87
gringoloco87 is on a distinguished road
whats the best head gasket out there for 7m i got 87 supra with a 91 jdm 7mge swap old engine was from a junk with unknown miles anyway before replacing engines i did the following
new
water pump
timing belt and tensioner
full gasket kit
hks 1.2 bead hg
thermostat
all the hoses coolant and vacuum
plugs
wires
cap and rotors
arp head studs
you know the basics of buying a used car
any ways 700 miles later she overheated heated and heard a knock i the lower half of the engine so i started to take it apart again took the head off to see the valve to see if i bent one and went to take the hg off and it fell apart in 3 pieces so now im going to do a full rebuild pistons valves bearings and a port and polish the block and head only have about 30k on if that
so basically whats the best head gasket out there need something thats going to take a hell of a beating
thanks guys
next summer 1uz tt build
gringoloco87 is offline   Reply With Quote
