yup, it is possible to build a "7M-GE(T)" but to be honest by the time you've faffed round with building and setup and crap you may as well just fit a full on GTE setup... although the GE bottom end is identical just needs turbo oil feed/return opening so if yours is known good with perfect hot oil pressure etc. and you can get hold of a knocking GTE engine plus ECU, loom, intercooler/piping you could do it that way...
