Old 11-26-2010, 03:06 PM   #1
dlfred
dlfred is on a distinguished road
Default Growling or rumble strip noise from rear of car.
There is a noise coming from the rear of the car that sounds like a growling, or small rubble strips. It seems to be worse under deceleration and "seems" to get quieter when I push in the clutch and coast at speed. It has gotten worse at a fairly rapid rate. I tried to check the bearings by jacking up the car and trying to get movement from the wheel assembly, nothing there. I just recently replaced the drive shaft support bearing, it seems fine.
The backlash, measured by twisting drive shaft back and forth and looking at yoke, only moves 1/4 inch.
I don't know if the clutch could cause this type of problem but it seems to work fine, no slipping.
It really sounds like the diff or a bearing. Thanks in advance.
1986.5 Supra 3.0 5 spd
1986 Supra 3.0 NA Stock
5 Spd. Lexus rims 16 x 7
dlfred is offline   Reply With Quote
