Old 11-26-2010, 06:52 PM   #4
Originally Posted by bioskyline View Post
on the non turbo motor a hose clamp bracket is attaced to that, so yes you can plug it
Not on all models.... At least not in US market N/A MKIIIs nor have I seen it used on any turbo models here. If any US models make use of it then it would be automatic transmission specific. There should be no need to plug it as it's nowhere near drilled all the way through... it may be plugged if needed though.
