Additional Info
The transmission shifts great. There doesn't seem to be much vibration coming through shifter. You can feel vibration through seat if you place your hand on seat while moving. So it feels like it is coming through the chassis rather than the drive-train.
That could be good news, right? With the wheels off the ground it seems to turn the diff gears smoothly. I did find one diff to sub-frame bolt loose . All the rest are tight.
I thought a wheel bearing making that kind of racket would be loose when pulling on wheel. So basically I have run out of Diagnostic Talent.
1986 Supra 3.0 NA Stock
5 Spd. Lexus rims 16 x 7
