starter is a total pain in the ass.
do it what ever way you think you can...
i just remove the upper and lower intake plenum, and it makes it easier.
if you don't want to take it apart, you should be able to get the lower one from under the car, and then worm your arm inside and find the top bolt.
only crappy part is after the bolts are off you got get it out, and get another one in there...
