Old 12-05-2010, 03:42 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by deanja8 View Post
Oil level is ok. Thanks pwpanas!
I went to start it up today, and now both light are staying on... I shut it down and restarted the car (hoping the lights will go away), no luck they're still on. Any other suggestions? I also noticed that when I looked under the hood for anything that may cause the problem, I heard a hissing sound coming from the "Resistor Pack Part# 28515-46010" (at least I think it came from it) when the car was off. Is this normal and can this be the problem or is it another issue that I have?
Thanks
It's not normal for the resistor pack to hiss. Although this is part of the electronics (obviously), I doubt it's related to your oil sensor.
If your master warning light is on, you'll be able to read the code(s) to determine the problem.
Life begins at 30psi.
