Originally Posted by bigd112
He put in a boost gauge and when I turn the car on, it goes straight to 30psi. The vacuum line is tapped into one of the MAF hose vacuum line that go to the intake manifold. Is this were the proper set up is?
You need to put the vacuum hose for the boost gauge into the intake manifold. just tap it into one of the vacuum lines with a T thingo.
Or there may be a spare one available
