Airbrush is used for touch up work very often... it doesn't always mean someone's getting a nude mermaid in front of a waterfall painted on their hood.... although here when someone says they're getting something "airbrushed" that is EXACTLY what they mean.
Yes, you can drop the GTE in there and run it like a GE. You'll have less power (lower compression ratio) and you'll need to swap a number of parts over from the GE though; These include: injectors, upper intake plenum, flywheel, distributor, N/A spark plugs would be a good idea.... etc.
