For plug wires you don't need to remove the Y pipe, just unbolt the throttle body, disconnect the IAC hose (the 1" hose in the front side of the TB), the throttle linkage and the one vacuum hose running to the thermostat housing and then flip the TB over so it rests on the Y pipe.
