well... fuel cut isn't set on rpm or boost really... it's purely on flow of air... so on a cold night you will be more likely to hit it... are you running stock boost? no boost controller hiding in there anywhere?
then you can go 110 cruising (5th gear)
cruising
h34r:
you should definitely not be hitting cut
explain more of your fco issues
