Old 12-25-2010, 03:02 AM   #1
2JZDU
2JZDU is on a distinguished road
1) The garage you took it to sucks. If the check-engine linght comes on, there will be a code stored in your ecu.
2) What you've described seems to be a tough problem to diagnose. Perhaps a sticking idle-air control valve?
I'd suggest starting by reading your own codes:
http://www.mkiv.com/techarticles/eng...bd1_codes.html
http://www.mkiv.com/techarticles/eng...bd2_codes.html
I'd suggest you should also check for boost/vacuum leaks by pressurizing your charge-air system.
Tnak you, I will try to diganostic by my self.
another problem is, I started the car at afternoon, everything are nonrmal, no engine light, boost and rev are fine...this is completey doesn't make sense
does the car like to stay under sunshine????
2JZDU is offline   Reply With Quote
