Old 12-31-2010, 05:03 AM   #4
Supra Saiyan
Supra Saiyan's Avatar
Supra Saiyan is on a distinguished road
Default T4 T04B Turbocharger
is a
crap compared to a stock ct26??
I am trying to understand all this but after reading so much and looking on supra forums. The different pricing around the web are making things worse. I can get a T4 T04B Turbo for around $200 shipped.
These specs..
Air Inlet 3" Cold Air Outlet 2" Bearing Wet Floating Bearings Oil Inlet 1/8 NPT Oil Inlet Flange Standard T4 Flange HP ~400 WHP Working Pressure: 5-25 PSI Peak Boost Output Capability Compressor .60 A/R Compressor Turbine 1.0 A/R Turbine Compressor Wheel 0.57T Compressor Wheel
Exducer: 2.32"
Mayor:3.00" Turbine Wheel High quality T04B with forged turbine propeller wheel
Exducer: 2.07"
Mayor:2.36" Hot Side 3" V-Band Works for
Perfect for any 4-8 cylinder.
Part #:ETD-TRB-T4-1AR-V
I can get a custom down pipe and all of this installed for $600..
Supra Saiyan is offline   Reply With Quote
