Called up the guy at drift motion. He was very helpful. I will be putting in the order for the 57 trim jan. 5th. Then send him the core..
The 57 trim besides being able to take more boost will have a much quicker spool right? See I don't have the boost controler yet, not the fuel upgrades either. I don't want to go messing other things up. I will be installing a 3'' down pipe with the turbo.. I already have a 3'' exhaust. Just a little side note..
Originally Posted by Green7mgte
if you go t4 your gonna new to get the t4 adapter for your exhaust header or just get a t4 exhaust header.. good upgrade imo
I would probably go ct-26 57 trim from driftmotion send them your old one and they will rebuild it with gerret internals or if its not rebuildable you can buy one for around 600. 500 if they use the core.
there is a large discussion about using the cx racing turbo on supramania.
also one about monsterpower turbos. the general agreement is.. run it till it blows.. then buy another one there so inexpensive. havent checked the thread in awhile but so far it seems it was a mixed bag. from people stating them crap. to others running 14 or more boost having it for a year or more.
cx racing isnt a drop in. it is not oil and coolant cooled. oil only. so you have to get a bypass hose for it.. that is sold on drifmotion also.
good luck.
