Old 01-02-2011, 11:57 AM   #17
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by 2jzFUN View Post
Well the short block is assembled and now I will be moving onto the process of building the head. The block consists of the following
-stock block
-stock crank
-ARP main studs
-ACL race main and rod bearings
-Custom 9.5:1 .020 over CP pistons with ceramic and oil shed coating
-Manley Turbo-tough rods oil shed coated
Photos to come.
Just curious - how did you decide on 9.5:1 as your CR? That's really pushing the edge as far as boostability...you'll likely have to run pure (i.e. don't blend with pump gas) VERY high octane race fuel ($$$$$$$$) if you're planning to make a lot of power from your boost.
Before you bolt on your head, consider a thicker-than-oem headgasket to help compensate for this (to me) overly-high CR.
Also, before you bolt on your head, consider modifying your block for 1/2" head studs OR be sure to get L19 studs. Oem-thickness regular ARP studs won't hold 40+ psi of boost.
Life begins at 30psi.
