87 Supra N/A to JDM 7MGTE and R154 Swap Complete
I just picked up an 87 N/A supra with a JDM 7MGTE swap complete running just fine with a R154 transmission
Now I do have some concerns, it still has the 7MGE wire harness. Wouldn't that cause some problem's?
I believe it has the 7MGE fuel pump will that cause a problem?
It still has the 7MGE MAF sensor, what will that do?
7MGE ECU is that a problem?
I also noticed it has a distributor instead of the coil pack is this hurting the 7MGTE?
What ever the case I'm just glad to be back in a turbo supra!!
